Engine Performance problem
2003 Ford Expedition V8 Two Wheel Drive Automatic
I have a 2003 ford expedition it has been missing fo a while now. I brought it to a local garage the mechanic said the number four cylinder was missing. I recently replaced the motor with another 5.4. I replaced all the plugs an coil packs, however the miss is still there. I went back to the same garage an the mechanic hooked the computer. It shows the same code, number four cylinder misfire. What should I try next?
Dec 22, 2009 at 6:02 PM
