2002 Ford Expedition Vibration while transmission shifts ar
112,367 MILES • V8 • 2WD • AUTOMATIC
SAILOR1969
  • 11 POSTS
I recently purchased a used 2002 Ford Expedition with 103,000 miles and took the family on a trip. The first thing I noticed was at around 1500 rpm and 2000 rpm, while gear changing, their is a vibration that tapers off after a few seconds. I have tried giving it more gas to see if it does this under pressure and it doesnt. Only when driving under normal circumstances. It doesnt vibrate when I am sitting idle and revving the engine nor does it miss. I have tried to see if anything would come up on an error code reader but nothing shows up. Any help would be appreciated. Thanks
Jan 8, 2008 at 11:48 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the trans is "shuddering" . Try having it serviced to see if it will help.
Jan 9, 2008 at 4:31 AM
SAILOR1969
  • 11 POSTS
I had the transmission serviced the day after you responded to my question on the 9th of January 2008. The shuddering is still happening. The mechanic said the pan was clean "like brand new" to be exact. He also said the noise should disappear shortly and that he didnt have time to drive it to see if it already resolved the issue. Can you give me a time frame that is should happen? I dont want to go too much longer and take a chance on something serious happening while in the middle of no where. Thank you
Jan 22, 2008 at 11:23 AM
2CARPRO JACK
  • 11,533 POSTS
If it is going to help, it should do it within a few miles. Doesnt take long for the trans fluid to mix together. If it is still doing it, might want to have a trans shop look at it
Jan 22, 2008 at 11:24 PM
SAILOR1969
  • 11 POSTS
It has taken close to 11000 miles for it to straighten out. Bought a transmission just in case it went out but never did. I guess everything needed longer to absorb and condition back right. Took the new transmission back since I havent had another problem with it. Thanks so much for the help!
Still going strong! Just went over 134,000 miles and almost 2 years later. Shuddering still cured. Thanks for the great advice!
Jul 6, 2008 at 6:25 AM
