2002 Ford Expedition Speedometer will not work
100,183 MILES • V8 • 2WD • AUTOMATIC
ADAN123
Speedometer will "wiggle" at low speeds and when not accelerating in Drive. I wanted to know whether its a sensor or a module or anything else that might need replacing. Thanks if your're able to help.
Apr 17, 2010 at 9:43 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on?
Do you have a tranny shift concerns with erratic speedometer operation
If so this may be caused by the speedometer drive gear or speed sensor
Check for codes
Apr 18, 2010 at 2:24 AM
