2002 Ford Expedition speed control
BULLRUN57
Electrical problem
2002 Ford Expedition V8 Two Wheel Drive Automatic
cruise control stopped working. checked fuse. fuse is good. what else should I check?
Jul 20, 2010 at 6:25 AM
  • 110,251 POSTS
Is the trans still shifting correctly?
Jul 20, 2010 at 3:44 PM
  • 110,251 POSTS
If the trans is shifting fine, then that eliminates the vehicle speed sensor (VSS). If the fuses are all good, then you need to check the switch itself to see if power is getting to and through it.
Jul 21, 2010 at 8:27 AM
