brake light fuse
96,000 MILES • V8 • FWD • AUTOMATIC
NOTREDAME1
how do i find brake light fuse?
Mar 14, 2009 at 6:55 AM
MERLIN2021
  • 17,250 POSTS
Here is a guide to help you test for power at the fuse and the fuse panel diagrams below. The fuse is F1.2
Mar 14, 2009 at 6:59 AM
RUBIOWELLNESS
Electrical problem
2001 Ford Expedition V8 Two Wheel Drive Automatic
My driver side rear brake light does not come on when i hit my brakes. It does not go on when I use my left turn switch either. I checked the bulb and I checked the fuse. All seem intact. The front driver side turn signal works but it flashes very rapidly. I am sure it has something to do with the rear light not working. Any suggestions?
Apr 16, 2019 at 5:06 AM (Merged)
  • 110,248 POSTS
I think you are correct. The symptoms you described are that of a burnt out tail light. Remember, there are two elements in the bulb. One is a parking light the other for the signal and brake light. Have you tried replacing the bulb with a new one? Have you checked the light socket to see if there is power to it with the brakes?
That fast flashing front light indicates the rear light has an open curcuit which means the power isn't going through it fully. Check it with a test light or new bulb and let me know what you find.
