2002 Ford Expedition Banging noises from the front
125,000 MILES • V8 • 2WD • AUTOMATIC
SAILOR1969
  • 11 POSTS
When I drive on a rough surface and hit a bump, like a manhole cover with either tire, there is a knock somewhere around the tires. It only happens to one side unless the bump is long enough to reach both tires at the same time. I actually sounds like a shock has broken off and is banging against the spring but they are fine. I have changed the sway bar bushings but didnt help. The vehicle seems to have become a bit more "bouncy" since this has started. I have been told it may be the A-plate bushings. I have no idea how to check this. We are getting ready to go on a long trip so any help with this would be appreciated.
Jan 14, 2009 at 2:53 AM
2CARPRO JACK
  • 11,533 POSTS
Most bushings can be seen if under the vehicle, they are apparent when bad. You can lift and support the front end and get under it with a small pry bar and see if there is excessive slop around the bushings on the upper and lower arms. Also check the shock bushings
Jan 14, 2009 at 1:29 PM
