AFTER VERY COLD TEMP MAYBE COINCIDENCE RADIO WITH NO POWER AUDIO FUSE BLOWN REPLACED BLOWN AGAIN NOTICE RECENTLY CRUISE CONTROL DOES NOT WORK
Feb 17, 2010 at 2:40 AM
2CARPRO JACK
✓Experienced Mechanic
Does it have steering wheel controls for the stereo and cruise? the temp may have been a coincidence, but there arent to many things that the stereo and cruise share as far as circuits go.You could try unplugging the cruise control unit under the hood and see if it stops blowing the fuse, if that doesnt do it, you may need to pull the stsreo out and unplug it to see if it is shorted
Feb 18, 2010 at 11:50 PM
DOULAW
MEMBER
[quote:905bfc5667="2CarPros Jack"]Does it have steering wheel controls for the stereo and cruise? the temp may have been a coincidence, but there arent to many things that the stereo and cruise share as far as circuits go.You could try unplugging the cruise control unit under the hood and see if it stops blowing the fuse, if that doesnt do it, you may need to pull the stsreo out and unplug it to see if it is shorted[/quote:905bfc5667]
