2002 Ford Expedition alternator
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGORIO LOPEZ
how do you change the alternator for a 2002 ford escape.
Jun 24, 2009 at 10:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following: Negative battery cable Right side intermediate axle shaft Right side splash shield and retainers Drive belt Alternator electrical connectors Alternator. Torque the mounting and adjusting bolts to 35 ft. lbs. (48Nm). Install or connect the following: Alternator ; Torque the bolts to 35 ft. lbs. (48 Nm). Alternator electrical connectors Drive belt Right side splash shield and retainers Right side intermediate axle shaft Negative battery cable
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e8dd7_1.jpg
Jun 24, 2009 at 11:37 AM
