2002 Ford Expedition
JIMMY352
  • 2002 FORD EXPEDITION
  • V8
  • 4WD
  • 85,000 MILES
When I accelerate hard from a dead stop I get alot of surging and a lack of power, what could it be?
Saturday, June 13th, 2009 AT 1:11 PM
  • 109,885 POSTS
Has the check engine light come on? Also, does the engine run good after pulling out and does it seem to have good power?
Thursday, June 18th, 2009 AT 11:58 PM
JIMMY352
The check engine light has never come on, and the only time the surging stops is when I let out of the throttle or when it shifts, other than that the power seems to be ok. I guess it would help if you had a little more info, I have installed a cold air intake and a dynamics tuning chip, if your not familiar with dynamics tuning it is a resister type chip that plugs straight into the mass air connection leaving the wiring for the mass air unconnected, other than that the engine is stock. I bought it used and don't know if it's ever had a tune up, so would worn out spark plugs or coil caps be causing it, or could it be something else?
Sunday, June 21st, 2009 AT 7:57 PM
  • 109,885 POSTS
I don't think a general tune up would help this. Did the vehicle do this prior to the chip? Also, to me it sounds like a throttle position sensor or idle air control valve problem.
Sunday, June 21st, 2009 AT 8:30 PM
JIMMY352
It didn't do it prior to the chip so maybe the chip is the problem but I don't know, the other day I tested it to see if it would surge any other time than just from a stop and everytime I would step on the throttle to get maximum power it would surge, whether it was from a stop or if I was passing it would surge until it shifted or until I let out of it.
Thursday, June 25th, 2009 AT 7:28 PM
  • 109,885 POSTS
If I had to guess at this point, I would say it's the chip you used. Can you remove it an try it that way?
Thursday, June 25th, 2009 AT 8:29 PM
Related Engine Low Power Content
