2002 Expedition warning light/fuel issue
FIXIT06
My warning light came on a week ago. The owners manual suggested adding mid-grade fuel and the light should go out. I have added the mid-grade and the light is still on. Do you know if there is another way to correct the problem before I take to Ford so they can correct. I only have 23,000 miles on the truck and can't imagine that there is anything major wrong.
Jul 4, 2006 at 12:06 PM
TAURUSWHEEL
  • 718 POSTS
What is the warning light??? Do you mean check engine or service engine soon light???.. sometimes if the problem fixes itself or is manually repaired, if you don't turn the light off, it may or may not shut itself off after a certain number of warm-up cycles.. what was the code you got , if any, from the light?? If needed, did anyone scan for codes??? 23k doesn't mean much, problems can crop up anytime,, is this vehicle still under warranty?? I believe federal law extends certain emission control components to 8yr, 80k miles..
Jul 4, 2006 at 1:18 PM
