2002 Ford Expedition Intermittent Misfire
RMCDONOUGH
I have a 2002 Expedition that has 147,000 miles on it. I had the transmission replaced with a Jasper transmission when the stock transmission failed. Since then it has been running rough when cold and missing intermittently at idle speeds in or out of gear as well as missing at highway speeds. It is most noticeable when first started each morning. I have had the plenum cleaned, fuel filter and fuel pump replaced and it still misses. I have removed each spark plug and dryed out any moisture in the coil connections. Any ideas?
Jul 7, 2007 at 4:23 AM
2CARPRO JACK
  • 11,533 POSTS
Could be an injector that is sticking. Have the PCm scanned to see if it stored a code for the cylinder that is missing.Might also be a coil that is going bad, have replaced both for this type of problem
Jul 8, 2007 at 1:08 AM
Suggested Repair
Scan the PCM for a stored code identifying the missing cylinder. Check for a sticking fuel injector or a failing ignition coil, both of which have caused this symptom.
Conversation Summary
A 2002 Ford Expedition with 147,000 miles and a replacement Jasper transmission runs rough when cold and misses intermittently at idle and highway speeds, especially after a cold start. Plenum cleaning, fuel filter and pump replacement, and drying coil connections did not fix it. The expert suggested scanning the PCM for a cylinder misfire code and checking a sticking injector or a failing coil.
