2001 Ford Expedition Sensor leaking brake fluid
REALPE
  • 2001 FORD EXPEDITION
  • V8
  • 4WD
  • 97,000 MILES
Hi, my sensor that is connected on the front of the master cyclinder is leaking break fluid. I wanted to know if I n eed to replace the sensor only, or the master cyclinder or both? Please help!
Tuesday, December 29th, 2009 AT 3:10 PM
  • 109,885 POSTS
I believe the sensor you are refering to is to shut the cruise control when you hit the brakes. The sensor itself needs replaced not the entire master cylender. Keep in mind, three was a recall on the wiring to the sensor. I believe it included up to 2001. Check with your local Ford dealer to check on that. THe original wiring was causing fires.
Sunday, January 3rd, 2010 AT 12:00 AM
