what does that mean running to lean thats what the coed said. and how to fix that.
Nov 22, 2009 at 10:48 PM
✓Experienced Mechanic
Basically that means you are getting too much air into the engine and not enough fuel. If could be cause by several things. THe first thing I would check for is vacuum leaks. A vacuum leak will allow more air to enter the engine.
