2001 Ford Expedition running to lean
13,500 MILES • V8 • 2WD • AUTOMATIC
COOLWILLIEC1
what does that mean running to lean thats what the coed said. and how to fix that.
Nov 22, 2009 at 10:48 PM
  • 110,251 POSTS
Basically that means you are getting too much air into the engine and not enough fuel. If could be cause by several things. THe first thing I would check for is vacuum leaks. A vacuum leak will allow more air to enter the engine.
Do that and let me know what you find.
Nov 25, 2009 at 3:18 PM
