When u remove the boot /plug wire from plug does it come out with oil? Or is it that it has oil on bottom side of plug when u remove it?Possible the gasket is bad. Its missfiring?Do u have check engine light on?If its missfiring its possible that u have a bad coil on number 4 or any other. Each plug wire comes with a coil I believe. Turn on the motor and disconnect each coil 1 by one and see if it missfires, if it does that coil is good connect it back and check onother and so on. If one does nothing no missfire shake etc then thats the one that is bad. Good luck.
SPONSORED LINKS
Wednesday, August 6th, 2008 AT 5:37 PM
