2001 Ford Expedition fuses or relays
CDM9579
  • 2001 FORD EXPEDITION
  • V8
  • AWD
  • 100,000 MILES
I was replacing a passenger side mirror. I was also replacing a window regulator. I did not unhook the battery. I had the radio on and somewhere in the process the radio went out and the car will not start. There is a taping in the audio relay and the powertrain control module. I replaced both and still won't start. When I turn the ignition on the radio and other circuits work for a bit then shut off. Everyone once in a while the engine will crank once or twice and shut off
Monday, May 25th, 2009 AT 9:05 AM
MIKE H R
  • 3,094 POSTS
Check the fusable link under the hood with the headlight relays. You can try disconnecting the battery and leaving it off for a couple of minutes then rehook it. This may help reset the computer in case a wire had been crossed.
Monday, May 25th, 2009 AT 11:09 AM
