a block away from my house the engine died and i coasted to the side of the road. I had a oil warning and a battery light on. the engine would turn over but would not start. the oil level was low so i put in a couple of quarts of oil but the light would not go off.
I towed to car home attached a fuel gauge. no pressure. the only trouble code on the pcm was a
P0401. I suspect the pcm shut the engine down to protect it from the low oil pressure. if thats the case, how do i clear that from the pcm?
May 20, 2010 at 3:16 PM
