2001 Ford Expedition DISARM
HORACE FRIEND
Engine Performance problem
2001 Ford Expedition V8 Two Wheel Drive Automatic 75000+ miles
A mechanic says my vehicle won't start because of the alarm dispite my having no alarm except the "thift" light flashing. How do I disarm the alarm?
Aug 26, 2010 at 10:40 AM
  • 110,248 POSTS
Your mechanic is correct. The system can't be disarmed. You can over ride it if you turn the key to the run position and allow it to stay there for 10+ minutes. The light should go off and it should start.
The system has many components and is an integeral component in the PCM. Therefore, if the PCM doesn't get the right signal from the system, it shuts down.
I wish I had a better answer for you, but that is the bottom line.
Aug 26, 2010 at 2:09 PM
HORACE FRIEND
Hi Joe,
I turned my key to run (right) and waited for 20 minutes. The following lights were still on: engine oil,
battery, check engine, and washer lights. I started and still no response.
Aug 27, 2010 at 5:00 AM
  • 110,248 POSTS
Was the theft light still on while turning the key to the start position?
Aug 28, 2010 at 2:44 AM
TREETOP25
hey if your theft lite is lashing is it doing it in a code like 3 flashes 1 flash and so on. if so most likely your key lost programing and is bad call a lock smith and have him come make a new key and program it and cleare the code. if key is bad keep it but mark it so you dont use it or youll have to spend more money to clear code. keep key so if you lose the new one you can use it to make another.
Aug 30, 2010 at 11:07 AM
