2001 Ford Expedition CRANKSENSOR
100,000 MILES • V8 • 4WD • AUTOMATIC
STEPHANIES4147
I AM GETTING NO POWER TO THE CRANK SENSOR
Mar 5, 2010 at 6:07 AM
  • 110,248 POSTS
Have you checked the wiring to the sensor for continunity?
Mar 10, 2010 at 12:08 AM
STEPHANIES4147
there is no powerto the fuel pump....i have powqer to the relay????
Mar 12, 2010 at 12:14 AM
  • 110,248 POSTS
I believe on the passanger side (kick panel) there is a reset button for the auto shut down (ASD). Check it to see if that helps.
Mar 12, 2010 at 12:36 AM
STEPHANIES4147
[quote:7c17dc617d="Jacobandnickolas"]I believe on the passanger side (kick panel) there is a reset button for the auto shut down (ASD). Check it to see if that helps.[/quote:7c17dc617d]
i did that! there is no power to the enursher??asd
Mar 12, 2010 at 2:46 AM
