2001 Ford Expedition blinkers
52,000 MILES • V8 • 4WD • AUTOMATIC
JECKYL1000
i would like to know how to fix my blinkers, they stopped working, brake lights work, when brakes are on and i turn on the blinker the light dims as if only the lights are on, hazard light work as well, my expd. has the turn signals on the mirrors as well and they are not working either, please help.
Dec 30, 2009 at 11:51 AM
BLACKOP555
  • 10,386 POSTS
indicators on dash working or no?
do you hear the relay clicking?
Dec 31, 2009 at 3:32 AM
JECKYL1000
no indicators, and there is no noise
Dec 31, 2009 at 3:35 AM
BLACKOP555
  • 10,386 POSTS
so your getting no response. have you checked all of your fuses yet? may be time for a new relay. or you can try jumping the control terminals on the relay and turning the switch to see if a light will turn on even if its steady.
you say the brake lights dim. how much and do they pulse with how the turn signal would flash?
Dec 31, 2009 at 3:37 AM
JECKYL1000
the brake light just simply goes out, the light is what is produced from the normal light being on, i have not yet checked the fuse yet, but i will do that this morning.
Dec 31, 2009 at 3:42 AM
BLACKOP555
  • 10,386 POSTS
if they go out sounds like your brake switch is working. next step is checkign the wiring harness and the relay and fuse
Dec 31, 2009 at 3:43 AM
