2000 Ford Expedition Trouble Code P0171
88,000 MILES • V8 • 2WD • AUTOMATIC
RTRAVIS
I changed the spark plugs and now am getting a P0171 trouble code. I have douple checked the connections running from the air filter to the throttle body and everthing is tight (I had to remove this to get to the plugs). I have also cleaned the AMF with an electrical cleaning solution.
I don't get the code right away, seems like the engine has to reach operating temperature to trip the code.
May 24, 2010 at 7:30 AM
  • 75,988 POSTS
Lean condition: P0171
Could be caused by the following, low fuel pressure, dirty fuel injectors, leaky EGR and PCV valves and vacuum leaks-
May 24, 2010 at 7:50 PM
