I would like to know if the timing has something to do with the exhaust turning red...
Aug 23, 2010 at 1:17 PM
BLUELIGHTNIN6
✓Experienced Mechanic
definitely a possibility. if the timing is too advanced it will cause red hot exhaust. could also be caused by a bad throttle position sensor (TPS).
Aug 23, 2010 at 2:28 PM
MADMIKE1735
a clogged cat is another possibility, however a cat doesnt go bad on its own... something has failed causing the porcelain in the cat to melt.... hope this helps with ideas.
