2000 Ford Expedition timing chain
190,000 MILES • V8 • AWD • AUTOMATIC
POOKACHU
I would like to know if the timing has something to do with the exhaust turning red...
Aug 23, 2010 at 1:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
definitely a possibility. if the timing is too advanced it will cause red hot exhaust. could also be caused by a bad throttle position sensor (TPS).
Aug 23, 2010 at 2:28 PM
MADMIKE1735
  • 951 POSTS
a clogged cat is another possibility, however a cat doesnt go bad on its own... something has failed causing the porcelain in the cat to melt.... hope this helps with ideas.
Aug 31, 2010 at 3:14 AM
