2000 Ford Expedition running rough and burning oil
130,000 MILES • V8 • 2WD • AUTOMATIC
OPUSLU2
whay would make the car run rough like it is jumpy like on a dirt road but not and what would cause the car to burn oil?
Dec 26, 2009 at 10:25 AM
  • 110,248 POSTS
Many things can cause the engine to run rough. First, has the check engine light come on? Have you checked for vacuum leaks, has the fuel pressure been tested? Finally, as far as the oil, do you see blue smoke coming from the exhaust? Are there any leaks that you see? And, is this the 5.4L V8 or the 4.6L V8?
Dec 28, 2009 at 5:56 AM
