2000 Ford Expedition Running Hot
165,000 MILES • V8 • 2WD • AUTOMATIC
TRICIA ALLEN
My vehicle will not keep water in the or collant in the resovoir. It's like it evaporates, no water leaking out. Blows white smoke from tailpipe
Feb 6, 2010 at 7:22 AM
  • 110,248 POSTS
It sounds like you have a bad head gasket. WHen coolant enters the combustion chamber, it burns white, the same as you described coming from the exhaust. You will not see a leak because it being burned. Also, check the motor oil to see if any coolant is mixing with the it.
Let me know if you have questions, and thanks for using 2carpros.com.
Feb 6, 2010 at 11:09 AM
