My vehicle will not keep water in the or collant in the resovoir. It's like it evaporates, no water leaking out. Blows white smoke from tailpipe
Feb 6, 2010 at 3:22 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
It sounds like you have a bad head gasket. WHen coolant enters the combustion chamber, it burns white, the same as you described coming from the exhaust. You will not see a leak because it being burned. Also, check the motor oil to see if any coolant is mixing with the it.
Let me know if you have questions, and thanks for using 2carpros.com.
