HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Expedition
Brakes
Pads
2000 Ford Expedition Replacing brake pads
LDGALYEAN
MEMBER
2000 FORD EXPEDITION
V8
2WD
AUTOMATIC
159,000 MILES
How do I remove the front brake calipers?
Saturday, May 9th, 2009 AT 2:10 PM
MECHANIC
The calipers unbolt from the rear. There are two bolts holding them on. Here is a how to video for you to view on brake replacement.
https://www.2carpros.com/how_to/how_to_replace_brakes.htm
Let me know if this helps.
Thursday, May 14th, 2009 AT 12:50 PM
Please
login
or
register
to post a reply.
Related Brake Pad Content
2000 Ford Expedition Anti-locks
I Replaced The Pads And Discs On The Front Of My Expedition. Prior To The Replacement, The Anti-locks Worked Fine. Subsequent To That...
Asked by
Gcubed
1 ANSWER
2000
FORD EXPEDITION
GUIDE
Brake Pads Wear Unevenly
Uneven brake pads wear is a common problem with braking systems and can cause safety concerns. During any brake job when removing the brake pads you may notice that one...
Can't Find Main Line And Secondary Line Leading From...
I Want To Replace These Lines And Can't Find Them Without Paying A Couple Hundred From The Dealer. Looking For Another Source Online.
Asked by
jimmybaby
2000
FORD EXPEDITION
Adjustable Pedals
My 2000 Ford Expedition Has Adjustable Brake And Accelerator Pedals. The Motor Is Working But The Pedals Will Not Move Up Or Down. There Is...
Asked by
Ahmed
1 ANSWER
2000
FORD EXPEDITION
2000 Ford Expedition Brake Repairs
Brakes Problem 2000 Ford Expedition 4 Cyl Four Wheel Drive Automatic Client Just Requested To Replace Front And Rear Brake Pads...
Asked by
lizmarc
1 ANSWER
2000
FORD EXPEDITION
2001 Ford Expedition Losing Brake Pedal Pressure
Brake Pedal Seems To Be Engaging A Little Lower Than Normal. Truck Stops Fine However If At A Stop Light The Pedal Slowly Starts To Drop...
Asked by
Mgrizer
2001
FORD EXPEDITION
VIEW MORE
Replace Rear Brake Pads Rotors Lexus RX350
Brake Pads
How to Break In Brake Pads or Rotors
