2000 Ford Expedition radio and wipers
155,000 MILES • V8 • 2WD • AUTOMATIC
KJSMITH45
when it is rainy the radio goes off when the vehicle is put in gear. In neutral or park it will come back on but in any gear it goes off. the wipers will work fine when in park or neutral but they can not be adjusted once it is in gear. The Ford mechanic did not see any signs of a leak but has no idea what is wrong
Oct 24, 2008 at 2:32 AM
MASTERTECHTIM
  • 4,750 POSTS
i have seen this before and the problem is the transmission range switch. somehow it backfeeds and causes everything to go wacky. hope this helps
Oct 24, 2008 at 4:00 AM
