2000 Ford Expedition overhead compass and temp readout/ co
160,000 MILES • V8 • 4WD • AUTOMATIC
NOTHUMN1
I have an 2000 expedition. The readout is now only working off and on with the compass and temp in overhead console.
If I push button in hard sometimes it will come on stay on for a while eventually does not come on again.
I got another moduale out of a EB edition. It has a miliage readout to.
Will it work in my 2000 XLT. I am assuming they would not have used 2 harnesses and the engine sensors may be there for the milage readout to work to?
Part number.(sticker) F75F-10D898-BD
stamped on case id F75F-10D895-A
Thanks for your time
Russell
Apr 5, 2009 at 7:06 PM
JAMES W.
  • 2,394 POSTS
If the plugin connector will fit the replacement module, it should. Your original module sounds like it may have just had a connection problem.
Apr 6, 2009 at 12:38 PM
NOTHUMN1
do you think the MPG function would work since mine did not have originally?
Apr 6, 2009 at 2:22 PM
JAMES W.
  • 2,394 POSTS
You've got a 50/50 chance. Many times Ford wires the harness for most of the popular options whether they are ordered or not.
Apr 6, 2009 at 4:46 PM
