2000 Ford Expedition oil pressure /water temperature indica
RICHARDBOLOTANO
Engine Mechanical problem
2000 Ford Expedition Four Wheel Drive Automatic 30,000 miles
oil pressure indicator light and water temperature indicator light on after the engine has been started.
oil pressure gauge not working also.what do you think is the problem?is it electrical or mechanical?
note:this problem occurs after the engine has been started,engine cold
Jan 2, 2010 at 12:56 AM
  • 110,248 POSTS
Are you hearing any noise from the engine like ticking or knocking? Are the oil and coolant both full?
Jan 2, 2010 at 3:44 PM
RICHARDBOLOTANO
[quote:8269fa2940="Jacobandnickolas"]Are you hearing any noise from the engine like ticking or knocking? Are the oil and coolant both full?[/quote:8269fa2940]
there is no unusual sound like ticking or knocking,both oil and coolant are full
Jan 2, 2010 at 4:50 PM
