2000 Ford Expedition leak
TIGGERFAERIE
Transmission problem
2000 Ford Expedition All Wheel Drive Automatic
I have a 2000 Ford Expedition. It has a transmission leak. Been leaking for a while. Not that bad actually. The other day, as I got an oil change, the mechanic informed me it was really bad. It barely holds the tranny fluid in it. They said it was most likely a seal, but could it possibly be just the pan? Either way, about how much would it cost to fix and about how long? I am supposed to leave for Connecticut in a few days..I'm currently in Florida. If it's too much for me at the moment is there something I can do to at least get me there to Ct? Thanks in advance!
Jun 17, 2010 at 8:30 AM
2CARPRO JACK
  • 11,533 POSTS
Depends on what the leak is to the price and how long.If the trans has to come out for the front pump seal it could take about 2 days and be a few hundred dollars for the r&r plus parts, it will be a little more labor wise since it is AWD.A trans shop would probably be a better place than the local lube center for this kind of repair though
Jun 18, 2010 at 1:19 AM
