2000 Ford Expedition IS it tranmission
156,000 MILES • V8 • 4WD • MANUAL
SAMA
Today while driving, I starting going around 40 mph, my truck started roar up but not going in faster and my rpm hand started going way up. Can you tell me what the problem is?
Jun 17, 2009 at 1:16 AM
  • 110,248 POSTS
Make sure the trans fluid is full. It sounds like it was slipping. Did it only do it once or all of the time? Does it seem to do this in any one specific gear?
Jun 18, 2009 at 4:50 PM
SAMA
It does it all time when getting up to around 45 mph, also I fluid check and it was okay.
Jun 19, 2009 at 3:57 AM
  • 110,248 POSTS
Based on your description, it sounds like the clutches are sliping in the transmission. If that is the case, it will need a general rebuild. At this point, I would recommend having a transmission tech drive it to confirm my beliefs.
Let me know what you find.
Jun 19, 2009 at 10:07 AM
