I need to replace the fromt brake rotors. I have removed the brake caliper and the caliper mounting bracket from the backing plate. The rotor seems to be rusted on the hub and wont come off. I have tried WD40 and applying heat to try to dislodge, then using a hammer on the back side of the rotor to try loosen it up.....with no luck. It does not seem that the rotor is pressed on the hub.....
Jan 27, 2009 at 3:56 PM
