2000 Ford Expedition engine
172,000 MILES • V8 • 2WD • AUTOMATIC
DLM0024
if i run the a/c, my ford will leak oil. if not, no oil is 'seen' leaking. also, while starting off, it will have high rpms and low acceleration, then kicks in. is that engine vs transmission and what is the estimated cost?
Jun 14, 2010 at 6:55 AM
  • 110,248 POSTS
i'm not sure I understand the AC / oil leak issue. As far as the engine / trans, it sounds like the trans is either low on fluid or there is a sensor issue. Have any lights come on?
Jun 14, 2010 at 8:45 AM
