2000 Ford Expedition dtc
140,000 MILES • V8 • FWD • AUTOMATIC
JAMES_WICHMAN
Trouble codes:
P0171
P0174
P0301
P0442
Changed out injectors #1,2,and 5
New Coils and plugs throughout
cannot remove fuel filter to change out-have tool but too little room
Did not find a vacuum leak using brake cleaner on vacuum lines while idling.
Nov 27, 2009 at 9:55 AM
  • 75,988 POSTS
P0171/P0174
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Misfire at cyl no. 1 check the sparkplug/compression and injector on it
P0442-Evap leakage
Nov 27, 2009 at 11:05 AM
