2000 Ford Expedition
16,512 MILES • V8 • AWD • AUTOMATIC
LADONNAGE
I have P0401 egr insufficiant flow. I have changed the egr valve 2 times, i also cleaned the passage out, I am attempting to get a smog test completed. on my scanner it states egr insufficiant flow, but on the computer there states catalyst inc o2 inc, in which i just changed all o2 sensors, all convertors, all spark plugs, & all coil packs, the mafe, pcv system, heavy duty muffler, exhaust pipe and sealed. I do not understand what it could be. the vac. reg test ok as well. Please help I bought this 4x4 truck aug 2003, drove it the first time 10/31/2003, dec 2003, started my night mare since then 13 rear differentials, 1 front differential, 2 transmissions, 1 shop stole it and damaged the engine by putting a sticky substance in the oil and I had my engine rebuilt. I do not want to give up on it, but I can't pass the smog now.
Jul 18, 2010 at 12:01 PM
  • 110,251 POSTS
Are you getting good vacuum to the EGR?
Jul 18, 2010 at 2:53 PM
LADONNAGE
Since july 18,2010 I have received 3 codes on the obd. I have changed everything, egr, pcv, 2/3 pcv hoses, dpfe sensor,egr vacuum regulator sensor, vapor management control valve,ignition coils, spark plugs, 4 convertors, muffler, exhaust pipe, 4 o2 sensors
Sep 15, 2010 at 8:28 PM
