2000 Ford Expedition
2000 FORD EXPEDITION
150 MILES • V8 • AWD • AUTOMATIC
BADGIO1
I have a 2000 ford expedition that I have just replaced its transmission; and when I put it into gear, it moves but it moves slowly and only after I have floored the gas pedal. What could be the problem?
Mar 16, 2010 at 1:23 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 16, 2010 at 5:10 PM
