2000 Ford Expedition
218,000 MILES • V8 • 2WD • AUTOMATIC
GORTIZ1
THE FIRST TIME YOU START IT THE VEHICLE RUNNINGS FINE. IT'S AFTERWARDS, THE SECOND OR THE THIRD TIME WHEN YOU ATTEMPT TO START IT. THE CRANK DURATION IS LONGER AND AT TIMES IT WON'T START! I'VE HAD THE FOLLOWING REPAIR'S DONE, A NEW STARTER, NEW COIL PAK & PLUG, IDLE AIR BY PASS VALVE, EGR VALVE, AND A STARTER RELAY. THE BATTERY IS CHARGING WELL, AND I CHECKED AND CLEANED THE TERMINIALS, AND THE GROUNDS. COULD IT BE THE TIMING SENSOR? THANKS FOR YOUR TIME.
Oct 29, 2008 at 4:19 PM
  • 110,251 POSTS
Have you had the fuel pressure / volume checked?
Nov 11, 2008 at 4:24 AM
