2000 ford expedition
MONKEYBOY31
[b:558ad9746b]My expedition is making a howling noise at all speeds. Thought it was tire noise, put new tires on, still very noisy and getting worse. Wheel bearing? Transfer Case? How do you check transfer case for fluid?[/b:558ad9746b]
Dec 6, 2006 at 11:29 AM
WYNRYPEN
  • 52 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
Dec 7, 2006 at 5:30 AM
HEY_WIRE
  • 25 POSTS
It probly is your transfer case fluid. My four wheel drive was making that sound in 4high. look at the transfer case there should be a drain, fill plug. May look like a bolt loosen it if its at the right level you should expect to see some drain out if you can see any in there then even so you may not want to add more fluid i dont know how many mile it has been since last changed so it might be low and need a change its not to exspensive to have it changed if your a do it yourself person then be sure to drain all old out and replace with new i hope it stops the noise for you.
best of luck.
Dec 7, 2006 at 3:00 PM
BRUCE HUNT
  • 3,754 POSTS
How about something simple like a shield on a brake rubbing on a rotor?
Dec 7, 2006 at 3:25 PM
