1999 Ford Expedition Starter runs continuously after engine
1999 FORD EXPEDITION
23,000 MILES • V8 • 2WD • AUTOMATIC
CASADERUSSELL
One day the 1999 Expedition (4.6L) won’t start.
Turn key, lights dim (normal), something clicks (normal), nothing turns over.
After a lot of looking around and scratching our heads, a friend jumps me, it starts.
The non-start problem happens very frequently (2 out of 3 times) but I figure out I can short the starter relay to start the engine.
I replace the starter relay on the passenger side fire wall with one a friend had. Now the engine starts every time, but the starter won’t stop.
I try putting the old relay back on. Starter continues to run after engine starts.
I replace the starter with a new one. The new starter keeps running after the engine starts.
I buy a new relay. Starter still continues to run after engine starts.
I try to turn the key on (not start) position, and short the terminals on the relay. Engine starts, but starter continuously runs.
With key out, voltage across battery is 12vdc, voltage from starter to ground is 12vdc on one post and 0vdc on other.
Seems like something is telling the starter to keep going even though the engine has started. There are NO OBD2 codes present.
Suggestions?
Jun 2, 2010 at 7:31 PM
Either the ignition switch is shorting out internally or the start circuit is shorted to power constantly powering the starter relay- Do this disconnect the small wire mark S on the relay and turn key off and check for power if you have it-check above
Jun 2, 2010 at 8:23 PM
CASADERUSSELL
Put multi-meter on it with positive on the wire and negative lead on "S" post of the starter relay.
With key out there is 4.53vdc present.
With key in start position there is 12vdc present.
With key in run position there is 4.53vdc present.
I even treid to strat it, then remove the "S" connection. Problem remains.
I'm wondering if I need to replace the starter again.
Jun 3, 2010 at 2:59 AM
Do you have an extra small terminal ( I ) on the starter relay? if so try switching the small wires
Jun 3, 2010 at 9:26 AM
