1999 Ford Expedition Shifter Is Very Loose
MARCELLUSATKINS
1999 Ford Expedition Automatic
The shifter is loose and the vehicle has a very hard time going into park. Will often coast as if in Neutral. The shifter has to be pushed up very hard to finally park.
Jul 24, 2008 at 10:04 AM
MARCELLUSATKINS
Underneath the steering column, above the brake pedal is the shifting assembly. If you follow the thin shaft towards the steering column, you will find a plate with 2 allen screws. Tighten the screws and the shifter is repaired!
Jul 25, 2008 at 11:41 AM
MASTERTECHTIM
  • 4,750 POSTS
you beat me to the punch. try installing loc tite on the torx bolts, for some reason they always loosen up
Jul 25, 2008 at 12:06 PM
