1999 Ford Expedition shakes when I stop.
1999 FORD EXPEDITION
106,000 MILES • V8 • 2WD • AUTOMATIC
JOHANNA25
Why does my car shake when i stop? or sometimes is accelerate.
Jan 1, 2010 at 4:13 PM
Sounds like its misfiring/running rough:
Could be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Jan 1, 2010 at 4:38 PM
KMCGEE
If this is occurring mostly when you step on the brake the rotors may be warped and probably just need to be turned.
Feb 15, 2010 at 10:15 AM
