1999 Ford Expedition PLEASE HELP
16,700 MILES • V8 • 4WD • AUTOMATIC
CDPEOPLES
I bought this 99 ford expidition it was in great shape inside and out but the engine was blown. I had a new engine put in and drove about 50 miles antifreeze keeps pouring out had the radiator cleaned and a new water pump but it still pours out. Please help.
Dec 18, 2007 at 8:42 AM
MERLIN2021
  • 17,250 POSTS
Where does it pour out of?
Dec 18, 2007 at 8:45 AM
CDPEOPLES
It is coming from the over flow.
Dec 18, 2007 at 10:30 AM
MERLIN2021
  • 17,250 POSTS
cHECK or change the thermostat, could be stuck!
Dec 19, 2007 at 9:41 AM
CDPEOPLES
[quote:2171b4074b="merlin2021"]cHECK or change the thermostat, could be stuck![/quote:2171b4074b]
They changed the thermostat cleaned the radiator and put on a new water pump they checked the whole flow system and found nothing wrong and we also tried a new radiator cap. It still overheats and pours out antifreeze. You can usually tell when its going to overheat b/c the heat inside gets cold like the a/c is on.
Dec 19, 2007 at 11:23 AM
MERLIN2021
  • 17,250 POSTS
Could be a blown head gasket, or cracked head or block, have a block test done, this will tell you if any exhaust gases are present in the cooling system, A radiator pressure tester can also be used to check for a head gasket...
Dec 20, 2007 at 12:25 AM
