1999 Ford Expedition ODOMETER
88,000 MILES • V8 • 4WD • AUTOMATIC
DOODERDAD
Almost every time the fuel tank is filled,or the fuel cap is removed. The odometer will go off for at least 1 mile after starting out again.This isn't serious but is unusual. What could cause this? Also ,how much of a job is it to change the valve cover gaskets?
Dec 30, 2008 at 5:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This seems to be a common problem with the newer model Ford trucks and SUVs. There is usually a bad solder joint on the LDC display of the odometer in the Fords. This can be fixed by reheating the solder at the crack and letting it re-flow.
Valve cover gasket is not too hard to replace if you have a little knowledge of "turning a wrench". If you would like removal/installation procedures for this, please let me know and I will be happy to post them for you.
Hope this helps..
Thanks for using 2carpros.com!
Dec 30, 2008 at 5:46 PM
