1999 Ford Expedition OBDII code-P0171
DOUBLE R1959
Engine Performance problem
1999 Ford Expedition V8 Four Wheel Drive Automatic
new motor. left bank too lean. What should I check to fix.
Aug 27, 2009 at 12:09 AM
2CARPRO JACK
  • 11,533 POSTS
Vacuum leaks first.Check the rubber fitting where the PCV line attaches to the intake manifold, those always deterriorate and cause vacuum leaks.Check fuel pressure. May also be a bad Mass Airflow Meter, Fords have issues with them andthey will set a P0171, if you continue to drive it will usually set a P0174 (lean bank 2)as well as the P0171
Aug 27, 2009 at 12:47 AM
