1999 Ford Expedition loosing coolant
100,000 MILES • V8 • AWD • AUTOMATIC
KLWSKI1
I have a coolant leak that dose not look like its coming from the heater core hoses and is dripping down over the starter area at a good rate where could this coolant be coming from
Apr 27, 2009 at 8:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check water pump, thermostat and any coolant hoses these are most common areas. Also inspect coolant resevoir and radiator . Sometimes the leak can run down on other components making it look like the leak is in a diff. location then it actually is.
Apr 27, 2009 at 8:14 AM
