1999 Ford Expedition leak
1999 FORD EXPEDITION
202,000 MILES • V8 • 4WD • AUTOMATIC
MARK1226
I have a pink fluid coming from a spot just above the frame on drivers side ,looks like a tranfer type box with two hoses one in take one out flow, the fluid runs feom either the connection or a slit in hose but dont know what it is for and where leak quite is can someone tell me what it may be from or to?
thanks
Oct 1, 2010 at 12:53 PM
  • 110,244 POSTS
If it is pink, it sounds like transmission fluid. Check to see if it is low. Also, check the power steering fluid. Some people use ATF in them.
Let me know what you find.
Oct 1, 2010 at 5:27 PM
