Cabin air filter location and replacement
BONNETMK
V8 two wheel drive automatic. Where is the cabin air filter? I see one in the rear when I open the hatch. It smells like there is on under the dash. How do I change this one?
Thanks, BO.
Aug 5, 2009 at 1:53 AM
  • 55,649 POSTS
Hello BONNETMK, To replace the cabin air filter follow this guide to let you know what you are in for in this job. It is located under the right side of the instrument panel in the HVAC housing. Trim panel may have to be removed to gain access to filter. See Fig. 1.
https://images.2carpros.com/forum/automotive_pictures/62217_Graphic_20.jpg
Follow this guide. https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter Most of these cars do not have one so do not be surprised. Please let us know happens so it will help others. Best, Ken
Dec 2, 2016 at 7:46 AM
MICHAEL G. CHAVEZ
I recently purchased a cabin filter for my vehicle and I cannot find how to change it. The inside smells old, and I want to change that. Thanks.
Jul 16, 2018 at 9:28 AM (Merged)
  • 31,937 POSTS
Hi there, Removal and Installation: Cabin air filter is available as an optional dealer-installed kit. Cabin air filter installation instructions are included with the kit. If a filter is already installed, it is located under the right side of the instrument panel in the HVAC housing. Trim panel may have to be removed to gain access to filter
https://images.2carpros.com/forum/automotive_pictures/61395_Capture1_5.jpg
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter Most of these cars do not have one so do not be surprised. Cheers, Mark (mhpautos)
BVYSIP
Hi, I need to replace my cabin air filter for my SUV XLT (45,000 miles). Hoping to save a few dollars from this. I bought the filter but do not want to tear off the whole dash just to get to it. Can someone provide step by step assistance please. Did not really want to sign up and pester anyone but I did not see a "how-to" solution. I am hoping that mine will get a response. Thank you.
TANNER04
Air conditioning problem.
Six cylinder two wheel drive automatic.
Where is cabin air filter for Eddie Bauer model?
RACEFAN966
  • 5,029 POSTS
You probably do not have on your truck as this is a dealer install option. So unless it was ordered it does not have one. Now if it does it is located under the right side of the instrument panel. So remove the lower panel and check to see if you have one.
TANNER04
How to remove trim panel? (Cannot find any screws) Do I need any special tool (kit)?
KHLOW2008
  • 41,812 POSTS
The red circle indicates where the cover is clipped on. Pull it downwards to get the clip off and you can see the cover for the cabin filter.
