1999 Ford Expedition CK SUSPENSION LIGHT DISABLE.
1999 FORD EXPEDITION
BONNETMK
Suspension problem
1999 Ford Expedition V8 Two Wheel Drive Automatic
I REPLACED THE REAR AIR BAGS WITH SHOCKS AND COIL SPRINGS..
HOW DO YOU GET THE CH. SUSP. LIGHT TO GO OUT.
THE SUPERSTRUT REP. SAID TO CUT THE WIRE
FROM THE COMPUTER BUT I DISCONNECTED THE
SWITCH FROM THE AIR COMPRESSOR.
CAN I SHORT THIS WIRE TO MAKE THE SW. AND THE LIGHT GO OUT? GREEN WITH A WHITE STRIP
IF I CAN SEE IT CORRECTLY.
THANKS
BO..
Aug 5, 2009 at 1:51 AM
RACEFAN966
  • 5,029 POSTS
Ok behind the right kick panel there is a switch for the air suspension. Have you tryed to turn that off to see if that turns the light off?
Oct 7, 2009 at 3:27 AM
