1999 Ford Expedition
145,658 MILES • V8 • AWD • MANUAL
MICHAEL G
the truck fells like the frunt axels are ingage when it should not be. turnning right or left it pulls like it is stuck in 4wd, and makes a wineing noise
Feb 22, 2009 at 7:34 AM
  • 110,251 POSTS
Hi:
What you need to check is if the actuator on the transfer case is working. Have a helper change from 2wd to 4wd while you check for power to the actuator. If you are getting it, remove the actuator to see if it is working properly.
Mar 1, 2009 at 11:27 AM
